HD Shock Air pump
03-09-2009 | 01:39 PM
I keep mine in my saddlebag. Wouldn't be without it.
03-09-2009 | 01:45 PM
I use the one made by Progressive (I believe the make the one for HD), they both look identical except for the name and price.
03-09-2009 | 01:46 PM
I've got an older version of Harleys, it works good. I tried cheating with some cheap bicycle pumps but they wouldn't fit, so bit the bullet and paid the bucks.
03-09-2009 | 01:48 PM
If you cheap out and buy a bicycle shock pump, it will "work" but because thee gauge reads zero to 300 psi, it will be near imposible to tell exactly how much air you actually have in the shock.
HD, Drag Specialties, progressive all are good, and depending on where you buy it, ad when, there isn't THAT much difference in price
03-09-2009 | 02:12 PM
just my 2cents
all the pumping and leaking off every ride, was too much b\s. so I went with the progressives. no more crap to get in the way of the ride!
03-09-2009 | 02:18 PM
03-09-2009 | 02:44 PM
Could these shock pumps be used to fill a flat tire out on the road once its patched? Will the pump work with the schrader valve on a tire?
03-09-2009 | 03:30 PM
This HD Pump is great.......and yes you can fill a tire on the side of the road....go ahead and ask me how i know that.....
03-09-2009 | 07:08 PM
wow..thanks for all the responses...guess i'm gonna get me one
