Greasing the Neck Bearings
When I did my 10K service I found that no grease gun fitting would fit on the straight head zerk in my FLTR due to the fairing brackets. My dealer was supposed to fill the neck at the 1K service. When I got the stock one out it was obvious that no grease had ever gone through it. It was bone dry on the inside. I showed it to my service department. Lame excuses were all they had. ![Mad](https://www.hdforums.com/forum/images/smilies/mad.gif)
Same situation with me also. Dry as a bone after 2 servicing with lame excuses once confronted. I took out straight zerk fitting and installed 90 degree angle one. They are tight and somewhat of a pain to get to line up with all the wiring, but worth it knowing you have grease in your steering bearing. I used Mobil1 synthetic bearing grease.
While the bike is being assembled, the bearings are greased and then installed. After assembly, the only way to grease the bearings, short of disassembling the front of bike, is to fill the whole steering head with grease.
