Notices
Greasing the Neck Bearings
Old 03-09-2009, 11:05 AM
keltonkrew's Avatar
keltonkrew
keltonkrew is offline
not meaning to hijack this thread but where the heck is the zerk fitting on my 09 RK so I can grease it...I've looked all over for that damn thing (also, any suggestions on where to but a good service manual).Thanks
Old 03-09-2009, 11:08 AM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
Originally Posted by xxxflhrci
Normally, grease squirts out the top and bottom.
And continues to squirt out for another 3000 miles.
Old 03-09-2009, 11:16 AM
ryan_sach's Avatar
ryan_sach
ryan_sach is offline
I believe it is a 1/4" pipe thread fitting, very common. Also, if the fitting stops taking grease, try to take it off the neck, and put just the fitting back in the grease gun, squeeze the pump. if grease comes out, the fitting is fine, try having someone else pump the grease gun while you sit on the bike and turn the bars back and forth... that sometimes works.
Old 03-09-2009, 11:18 AM
ryan_sach's Avatar
ryan_sach
or take it for a little ride to get the grease to move in the neck a little, you should be able to see it come out eventually
Old 03-09-2009, 11:45 AM
ftanner's Avatar
ftanner
ftanner is offline
I have an 09 RKC...
Look up near the top of the frame where the neck is. It will be on the same side of the bike as the horn.
It's kind of a pain in the neck to see with the wire looking running right there.
Old 03-09-2009, 12:14 PM
FastHoss's Avatar
FastHoss
FastHoss is offline
Change to a 90 degree fitting,it will work alot better.
Old 03-09-2009, 12:34 PM
garyhendley's Avatar
garyhendley
garyhendley is offline
1/4-28 THREADS SIZE for the fitting buy a 45d fitting makes it easy to lube-ride safe
Old 03-09-2009, 12:35 PM
keltonkrew's Avatar
keltonkrew
Originally Posted by ftanner
I have an 09 RKC...
thanks....I found it....was hiding behind the wire loom and at least on the RK it's easy to get to now that I know where the damn thing is
Old 03-12-2009, 01:32 AM
ajay450's Avatar
ajay450
ajay450 is offline
Finally figured out how to work my grease gun. I put enough grease in to get some squeeze out at the bottom of the neck. But I did not see any at the top of the neck. Should I see squeeze out there as well? I would think. Should I keep going until I start to see grease at the top? Thanks again for the help.
Old 03-12-2009, 04:28 AM
XTrooper3936's Avatar
XTrooper3936
XTrooper3936 is offline
I think you're good.
Quick Reply: Greasing the Neck Bearings
