oil change
Old 03-08-2009, 09:37 AM
soos's Avatar
soos
soos is offline
Originally Posted by frankieb1963
funny i've seen your ads and never noticed the location. If it wasn't so sandy out I would definatly swing by. Another 2-4 tomorrow too......ARGH!
Take it slow and easy. Anyway, as a suggestion, where the SG is lower, if you had 3 pieces of 2x6x12" approximately you can roll your scoot up onto the 2 by's and put another piece under the jiffy stand. You now have additional clearance to get under the frame. Your drain plug is on the front left corner of the pan and ideally positioned for draining on the jiffy stand.
Old 03-08-2009, 09:39 AM
soos's Avatar
soos
soos is offline
Originally Posted by mayfly
on my 98 RKC the service maual has no pics of location of the different drain plugs - which one is the oil ? it salys to remove the plug from the oil pan - but I can't tell the difference between the trans and engine.
anyone have any pics or suggestions ?
Here ya go.
hdpearl70's Avatar
hdpearl70
hdpearl70 is offline
Get a service manual...outlines all necessary fluid changes at regular intervals
Old 03-08-2009, 09:57 AM
soos's Avatar
soos
soos is offline
Originally Posted by beary
I'm getting an 09 SG delivered next week, is it any different from my 02 RK? The reason I asked is I once read someone saying that the oil will drip on the frame if you drain it on the jiffy stand. I bought the manual, but they had to order it too.
Beary
Beary,
You are gonna get oil on the scoot no matter how careful you are. Oil changes are messy to begin with.
Old 03-08-2009, 10:07 AM
Suede Blue Man's Avatar
Suede Blue Man
Suede Blue Man is offline
Originally Posted by soos
Here ya go.
Now that's funny stuff right there, good visual aid Soos!!
Old 03-08-2009, 10:17 AM
weezo's Avatar
weezo
weezo is offline
I just did my 08 RK for the first time, it's easy. Get everything you need first, including a new O-ring for the drain plug. I did mine on a lift with no problem. You'll probably need the filter wrench, it's about $23 or so.
You might need to brush dried sealant out of the plug threads, apparently dealerships use some kind of dope when they change oil.
You're supposed to put the plug back in to a specified torque, there's been a lot of discussion about whether or not it's really necessary on these boards. Tight but not too tight, using the tq wrench is a sure thing.
Old 03-08-2009, 10:27 AM
beary's Avatar
beary
beary is offline
Beary,
Thanks, I've been changing oil everything from lawn mowers to airplanes all my life, so I understand. You don't know messy until you've change the oil in a DC 3. I'm just curious if the 09 is different from my 02.
Beary
Old 03-08-2009, 10:36 AM
beary's Avatar
beary
beary is offline
I've read this before. I don't recall it in my 02 manual and I've never use any kind of sealant on drain plugs except on the 02 primary. I've never had a problem with drain plug leaking and I usually check pretty often. Is it standard procedure for dealership?
Beary
Old 03-08-2009, 04:30 PM
soos's Avatar
soos
soos is offline
Well? How didja make out?
Old 03-08-2009, 04:35 PM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
At 4800 I'd do the full 5k service, but that's just me.
Quick Reply: oil change
