Motorcycle Metal HID
So today I made the purchase with Howard at Motor Cycle metal and went with their HID upgrade for my 2008 Street Glide. The bike is at the shop right now having some work done so I will be dropping off the light and instructions with my mechanic. I chose not to buy his aux switch because my street glide already has one that I am going to use to turn the headlight on and off after starting the bike.
I printed out the instructions for install as well as the wiring diagram for the mechanic. Is there anything I should know or advice for me to pass on before the install. Howard did his best to explain things to me, but in all honesty I was not tracking so much. He finished by saying its extremely easy, so I guess we will see.
http://www.motorcyclemetal.com/gpage12.html
Nick
Nick
Thanks Nick
Nick, Call me with the mechanic anytime or give him the card with my toll free # and I will go over it with him. I have included in this drawing how to install an interuptor switch (switch on right hand column 2/3 or the way down and instructions how to wire up a set of HID/Halogen piggyback bulbs so you can run Halogen w/wo a modulator during the day and HID (3) 35 watt HID lamps at night. You can do this with any bike but due to hiding the ballasts it is better to do it on Baggers.
to do this
to do this
If you use these, you won't have to hide the ballast because they are self contained.
http://www.trailtech.net/single_hid_scmr16.html
to do this
to do this
I'm about saving money and getting to learn my SG. Can I do this on my own without having to go to the dealer? What is the color number on your kit i.e. 4300? I would like for mine to look like it came with the SG and not that ugly blue purple looking light. What other options would I have? I have been looking for a HID kit besides harley and have yet to find one. Maybe you can change that?
Wally
How easy was the wiring? I passed on the box and instructions to my mechanic this weekend. My only concern is him figuring out the wiring for the aux switch. If all the instructions come in the box I am sure he will figure it out.
Nick
So today I had the kit installed by my mechanic, minus the aux switch. I found that every 3-4 times I turned the ignition switch on before starting the bike, at least once or so I had a malfunction with the light coming on. If the light didn't come on (before I hit run on the handlebars) I found myself turning he ignition off then back on. Most times the light ended up coming back on after a couple cycles of on and off. Anytime I turned the ignition switch on, and started the bike the light always continued to stay on if it was on to begin with.
I guess I am a bit confused as to why the light most of the time came on after turning the ignition to on, but then every so often the light would not work? If the light had turned on with the ignition in the on position, then quit after the bike was started, I could see where there might be a power issue and a need for an aux switch. But every time the light came on, after the bike was started I never had the light shut off. I also don't get why no other kit out there uses an aux switch with their HID kit? Anyone else care to shed some light on this. I am not to mechanically inclined so I am having a hard time grasping the idea and how to install the switch. Anyone here ever have this experience? Any help would be great.
Nick
(For the record....Howard has been a great source of help, and has never once denied any of my calls. I posted this thread just to get some ideas from other customers of his who have this light.......)
Nick
