HD Zumo dash mount
I installed the dash mount ,piece of cake. I would recomend using a small drill bit first, (about the size of the hole on the template ). then drill thru the side of the dash you look at while riding.It really looks good when it is installed. The only problem I see is the SECURITY SCREW is tough to undo if you have the screw driver on a key ring.
92366-08
IN-STORE PURCHASE ONLY Contact dealer for pricing and availability.
Fits '96-later Electra GlideŽ models (except FLHTCUTG). Does not fit with Road Tech™ XMŽ Satellite Radio P/N 76390-05A, '06-'09 Screaming' Eagle Electra GlideŽ models or models equipped with Fairing Dash Pad P/N 58262-05.
![Wink](https://www.hdforums.com/forum/images/icons/icon12.gif)
The MOCO GPS sucks so I bought the 550 ZUMO. I like the functionality of the Quest 2 much better than this pricey thing but the Quest 2 is too slow and no upgrade path.
I'll be installing the Fairing mount as soon as I get it and figure out what to do with the dash pad. I'll post some pictures when I get it done. But that will take a while with paint and all. I'm also thinking of adding the Fairing moted Radar Detector and may do both at the same time
