glue for grips?
Old 03-05-2009, 04:44 PM
BuddyinStL's Avatar
BuddyinStL
BuddyinStL is offline
Kuryaken grips require glue. I first used it on my VStar and I only used half a tube. The grip stayed on but would twist on the lower side. I installed the same grips on my Ultra, used the entire tube, and it is on there for good. I would rather have them on tight then the alternative.
Old 03-05-2009, 04:52 PM
harley-jones's Avatar
harley-jones
harley-jones is offline
If you decide to use glue make sure you do the throttle side first and then match the clutch side to it.
This is if the throttle side is already mounted on the sleeve.
Old 03-05-2009, 04:55 PM
BlackFLHR's Avatar
BlackFLHR
BlackFLHR is offline
I installed the Kury ISO grips on my RKC a few months ago. I used the glue that came with them. On these grips, you NEED to use glue for the left side, as it is not secured by the switch housing (as genuine HD grips are). The glue worked good... But about a month ago, I decided to try a different grip. To get the Kury off, I just grabbed a very tight hold on the grip, and started to twist back & forth. It came loose and slid right off. No damage to the grip or the handlebar. In fact, I just sold the grips yesterday to a guy. You coudn't even tell that they had been previously installed on a bike (yes, I did sell them as "used").
Old 03-05-2009, 06:55 PM
fyrdude's Avatar
fyrdude
fyrdude is offline
Thanks for the quick replys
I'll give em a go tomorrow. Thanks again
Bill
Superfly3176
03-16-2014 10:36 PM
GS357
06-16-2012 07:59 AM
nighttrainwayne
05-09-2011 12:12 AM
harley-jones
03-05-2009 04:04 PM
mhud
12-08-2007 06:18 PM
Quick Reply: glue for grips?
