best AIR FUEL RATIO
best AIR FUEL RATIO
I wrote this once but it got lost i guess. I am close to getting 1000 miles on my new 09 Ultra and will be having a dyno tune with the SE pro super tuner and Rinehart slip ons and SE A/c and would like to have the best AFR set at that time. The dealer said they set them at 14/0 but would set it where ever i wanted it. I was thinking 13/8 . What do you guys know about this. Thanks for the help. I get so much info off of the site that helps me make good choices.
What is causing your confusion is the way you are stating the a/f ratio. Your Heritage was not set at 13/2. I am guessing it was 13.2 / 1 or 13.2:1 or 13.2 to 1 However you want to say it. Meaning 13.2 units of air for every one unit of fuel. 13/2 would be the same as 6.5:1.
Look at the a/f ratios on my dyno sheet that I posted on your original thread on this subject. It will show you in a green line where it was from the factory and the red and blue lines will show front and rear cyclinders how it is set now.
Dennis
Dennis
I ask because AFR varies for all of those parameters and, with regard to acceleration and load, there is no single AFR that is "BEST."
In summer I will be able to switch to a richer map on the fly with the PCV, which allows me to run leaner mixtures most of the time for better mileage, then switch to a richer map when the going gets hot in summer traffic. You can't do this with SEST or TTS (AFAIK) so you'll need to find the best compromise for your type of riding.
If I were you I would tell them to tune it no richer than 14.2:1 (even leaner with an oil cooler) in the cruise range (5-20% TP) and 13:1 at WOT across the board, tapering the AFR's as TP's increase. Then if you are unhappy with the heat you can have them richen it. If you run leaner than 14.2:1 in the cruise range I would install an oil-temp gauge and monitor oil temps closely in summer. It wouldn't hurt to have one even with a cooler and/or running richer AFR's. Keep in mind that in stock form the O2 sensors keep AFR's at 14.6 from idle to about 50% TP.
