Notices
What Stabalizer Do you have.
Old 03-05-2009, 10:39 AM
drcarter0734's Avatar
drcarter0734
drcarter0734 is offline
TWR. I did a lot of research prior to purchasing it. I as others liked the simplicity of the design and you can't beat the price.
Old 03-05-2009, 11:01 AM
user 8373900's Avatar
user 8373900
user 8373900 is offline
Bagger Brace, without question.
Mark
Old 03-05-2009, 11:15 AM
jag1886's Avatar
jag1886
jag1886 is offline
I use the Ride Str8. It works well and was easy to install, the owner is also a nice guy that will go out of his way to help you or answer any questions.
Old 03-05-2009, 11:28 AM
asatguy's Avatar
asatguy
asatguy is offline
Throttle Up.
Old 03-05-2009, 11:32 AM
6 gun's Avatar
6 gun
6 gun is offline
Received 1,747 Likes on 982 Posts
Old 03-05-2009, 11:43 AM
RK05's Avatar
RK05
RK05 is offline
Progressive
Old 03-05-2009, 12:30 PM
mvinc01's Avatar
mvinc01
mvinc01 is offline
Throttle Up! Industries
No complaints. Nice improvement over stock handling.
Old 03-05-2009, 01:44 PM
roadking1893's Avatar
roadking1893
roadking1893 is offline
Thank you everyone for you great response. After reveiwing several of the web site suggested and had the apportunity to look over each design I decided to build one and put some of my machining tools to use since several of the design are basically the same and the material required I have laying around beside the heim joint rod ends.
I'll post the result when I am done.
Old 03-05-2009, 02:42 PM
HDRider2002's Avatar
HDRider2002
HDRider2002 is offline
Good luck with the fab work!!!
Old 03-05-2009, 03:09 PM
molsen's Avatar
molsen
molsen is offline
Sounds like a plan. They all do the same, for the most part. I think, if you have the abilty to make your own it will work the same.
Quick Reply: What Stabalizer Do you have.
