Exhaust Clamp Replacements
1. Yes, use two new flange gaskets. HD PN: 65324-83A
Flange tightening process:
Tighten the top nut of the front cylinder head exhaust flange to 9-18 in-lbs.
Tighten the bottom nut to 100-120 in-lbs
Then the top to 100-120 in-lbs.
2. Yes, purchase new H-D Torca clamps: 65283-94 and torque to 45-60 FT. LBS.
3. Shouldn't need it.
I've always replaced gaskets and used high temp copper sealer, no to clamps, just cause that's what I've always done does not make it right. But the new gaskets won't hurt, there are not expensive, and the sealer won't hurt anything either and the manufacturer of my bikes pipes(Rinehart) recommended both on initial install, so anytime they came off I followed the original procedure.
