Fairing Mirrors ??
As long as you have the same designed inner fairing where the mirrors would mount, they should work. If you pull your outer fairing and look at the backside of where they'd mount and it is doable then go for it. You might not be able to use the template the way it gets lined up using the lower mounting hole of the inner fairing, but that's a minor issue.
