Smart Siren II / Pager / Any one tried?
On my 08 you cannot adjust the sensitivy of the security unit. I had several items stolen awhile back including removal of 1 mirror. Having the siren is nice but the bike can be bumped real hard before the unit goes off. It seems that 08 and on the adjustment feature using the handlebar switches is gone.
Not difficult to install - plug & play. Make sure you follow the instructions carefully when velcroing the antenna onto the frame. I've never had the pager signal me someone was messing with my bike but that is probably because noone has yet. Having the pager just gives me peace of mind that if I happen to be somewhere that I couldn't hear the siren, I would be alerted. I would suspect the siren would disuade most people messing with your bike. As previously mentioned, the biggest knock on the security system is that you can no longer adjust the sensitivity - sometimes I would like it set to activate if a mouse farted nearby.
Installed both about a week ago very easy and the instructions suck, install is easy. On the 09 model where the alarm goes its a very tight fit, took me a few tries I did not want to break the tabs off. Install took less than 2 minutes once I convinced myself that the alarm really did fit in the space.
Like said it will take more than a bumb or a jostle to make it go off, great you get no false alarms. Bad though you could go through the bags, maybe even remove them without setting it off.
BTW there is no chirpless mode at least I have not found anyone who can get it work for the Smart Siren II.
Here is link of one of the Forum Members install.
https://www.hdforums.com/forum/touri...it-w-pics.html
