Chroming
Old 03-04-2009 | 05:46 AM
Mtn's Avatar
Mtn
Default Chroming
My brother has an 08 Fat Boy and I have a 08 Street Glide. He is putting on chrome forks and inner primary. He suggested I take the old parts and have then chromed, and use them on my bike. Is this a valid idea, seems to easy to me, wouldnt everybody be out buying up parts to chrome?
Thanks John
Old 03-04-2009 | 05:49 AM
HDUltraRider's Avatar
HDUltraRider
To buy parts and then chrome them would not be much cheeper then buying the part already chromed but if you are getting the parts for free it may be a good deal.
Old 03-04-2009 | 08:21 AM
Harleypingman's Avatar
Harleypingman
IIRC, his lower forks are single caliper; your bike has twin calipers. Also, don't know if the inner primary is the same on both bikes.
Some folks buy parts to have them chromed in order to avoid the downtime associated with using their own parts. As for chromed sliders, I initially thought about chroming mine, but bought the HD kit instead at 20% off list price.
Old 03-04-2009 | 08:28 AM
xxxflhrci's Avatar
xxxflhrci
If you buy take-offs and send them to a good chromer, you will usually have better chrome. HD chrome fork legs are notoriously wavy. The waves come from lack of enough polishing prior to plating. If you look at a set of HD legs and a set that a good chrome did, you will see a world of difference.
Old 03-04-2009 | 08:56 AM
rocknrod's Avatar
rocknrod
Dawg gave me a good idea (after I already bought mine) Take a inner primary have it drilled and tap at the top for a fill hole as it already has a drain hole. Also you can drill and tap the shifter shaft hole for a zerk fitting.
Old 03-04-2009 | 08:59 AM
Akitakoi's Avatar
Akitakoi
That's a good idea but how would you verify the correct amount has been added?
Old 03-04-2009 | 09:03 AM
xxxflhrci's Avatar
xxxflhrci
Dump in the specified number of ounces.
Old 03-04-2009 | 09:04 AM
rocknrod's Avatar
rocknrod
Or you could read your manual.
Old 03-04-2009 | 09:27 AM
masterblaster's Avatar
masterblaster
Thats a great idea, will do this on my Dyna, I will also send my front end to chromepros, thay do great work.
Old 03-04-2009 | 10:52 AM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
I have had great luck with these guys. http://www.chromemasters.com/
Quick Reply: Chroming
