fairing mount GPS - Nuvi 205W - hardwired to bike
Old 03-05-2009, 05:48 AM
Garemlin's Avatar
Garemlin
Garemlin is offline
Originally Posted by HilllBillly
I found the correct cradle to use, and the ball to mount on the back of the cradle... but can not locate the attachment for the ball to mount cleanly to the fairing (clean and sturdy)..... any ideas?
Go here.
Click on flat surface mounts.
Old 03-05-2009, 12:49 PM
jsimo7's Avatar
jsimo7
jsimo7 is offline
Here is my setup ...Ram mount and a plug in the inner fairing .. Works great and allows adjustment from bright sun and is right at fingertips ... also allows quick 2 second removal when parking the bike. It does leave the ball mount on the switch housing when not installed but the ease of use outweights the ball when its off the bike.
I also put pics of my Sirius radio on the glove box door. If it rains I put the sat radio in the pouch ... ride safe
this is with the gps unplugged and the waterproof cap in place
The sat radio wiring goes up through the fairing and plugs in to the factory cig lighter and the antenna is on top of the dash pad with the wiring under the fairing
Old 03-05-2009, 09:05 PM
Saxon's Avatar
Saxon
Saxon is offline
Default GPS Mount
Haven't tried this myself but it looks like a neat set-up
http://www.kuryakyn.com/index.cfm/go...cID/30/IMID/91
If the link doesn't work the mount can be found on the Kuryakyn website, under touring, rider comfort
Its a gps mount which replaces the fuel door
Old 03-05-2009, 09:20 PM
wrenchguy24's Avatar
wrenchguy24
wrenchguy24 is offline
I just bought a 2006 ultra last year it had a GPS unit and its base is mounted on the faring!!! I think this is a harley GPS unit?? Is this something you guys are interested in???? Im not going to use it! I do no its hardwired to the bike!!!
Old 03-06-2009, 04:40 AM
HilllBillly's Avatar
HilllBillly
HilllBillly is offline
This isnt a bad product - and i may end up trying it -- right now i'm just trying to configure a very clean fairing mount so the GPS is in my line of site as opposed to looking down at the gas tank..... but it is a good solution -- Thanks! I've never seen one in person
Old 03-08-2009, 02:59 PM
MetalHawg's Avatar
MetalHawg
MetalHawg is offline
5th Gear
Default Ram Mount for iPod
I use the RAM mount for my 60gb iPod and it works fine. Only bad thing is I cannot use the scroll wheel to look through songs since the ram mount has a plastic sleeve to protect it from rain doesnt let you do that, although you can FF or RW, Play or Pause the songs fine. I use it all the time.
Plus I can throw a litrle lock Master onto the mount to securely lock the iPod in place so it does not vibrate off.
Old 03-08-2009, 06:07 PM
rjmac53's Avatar
rjmac53
rjmac53 is offline
good info...
Old 03-09-2009, 06:13 PM
TheeDog's Avatar
TheeDog
TheeDog is offline
Originally Posted by Monstermile
Here is what you need to hardwire the Nuvi.
LINK
You can use the extra power lead and ground that is bundled with the headlight harness. Just pick up some spade connectors for the leads.
Great find! Thanks
VA_Larry
12-07-2015 05:41 PM
webbhead
02-16-2014 04:19 PM
stranchell
08-22-2012 04:57 PM
DeputyMike
07-20-2011 09:04 AM
kurtlange
04-25-2008 06:07 PM
Quick Reply: fairing mount GPS - Nuvi 205W - hardwired to bike
