+1 for clear silicone. Tape is ridiculously fragile and impossible to work with. Three small dots of silicone inside the rim of the chrome is all it takes.
+1 did the same thing, I think it took me about 10 to 15 min for all.
much easier to install if you use some silicone. I used the sticky tape that comes with them when I first installed them, then later on when I replaced my air temp gauge, i had to remove the ring and install on my new gauge. I used silicone and it was ez.
Easy to remove with a pick tool. A small hook. As long as you used just the tape or a small amount of silicone.
If you used lots of silicone or Krazy Glue you'll need a hammer and a blow torch.
