Heim Joint Specs?
#52
#53
I did the mod this morning, took all of maybe 20 minutes. Bought plain ones from local auto parts house and button head bolts in stainless from local hardware store. Total cost was 25.00. Will ride it for a while and then take the rod off and have the ends powdercoated flat black. Thanks to all for the info. Oh, and the bike does seem to shift better and the lever going down in the tranny, don't move around as much(got to get it replaced next month). Again thanks.
Joe
Joe
#54
wow, stainless that rusts? never thought that was possible, and it depends on the alloy, how much chromium etc is in the alloy, magnetic? yes, a lot of stainless is, check your fork you're eating with, you'll find that usually it will be attracted to a magnet. just depends on the alloy, i used to use hi tech, or so i thought stainless steel button head allen bolts, then realized, hey, the socket end of these allows an allen wrench to round out if you torque them much, then figured out that most hardware variety stainless is actually about grade five hardness. whooda figured huh?
#55
no it doesnt....stainless will never rust....if you use a non stailless tool or wire brush to clean it...it's the impregnated filings that are rusting...not the stainless. I work with stainless everyday...and work in a wet pet food manufacturing plant that has stainless in it 36 yrs old...not rusting.
#56
#57
#58
Joe
Joe
