View Poll Results: What Tuner???
SERT
13
52.00%
PCIII
11
44.00%
SERT & PCIII
4.00%
Voters: 25. You may not vote on this poll
Need Tuning Help Guys
My bike is a 06 Streetglide. When I bought my bike it had a V&H 2-1 Pro pipe with a Stage 1 SEAC wtih a SERT. Then I changed the pipes to Bub 7's True duals. Ran so rich it fouled plugs so I bought a PCIII and download a map for Rienhart true duals with Stage 1 SEAC and Stock ECM. Ran better checked plugs but no fuel milage. Now I just installed a SE Heavy Breather made the bike come alive but I still get pop on decell. Now I know I need to do something to adjust for the new changes and for the ECM not being stock.
So from the begining
1. V&H 2-1 Pro pipe, Stage 1 SEAC, SERT
2. Bub 7's True duals, Stage 1 SEAC, SERT
3. Bub 7's True duals, Stage 1 SEAC, SERT, PCIII
4. Bub 7's True duals, SE Heavy Breather, SERT, PCIII
My exhaust and air cleaner setup is the one thats staying on my bike.
Questions
1. Should I pull the PCIII & go get the SERT re dynoed & be done?
2. Should I map the SERT to a Stage 1 setup with duals & re map the PCIII?
3. Can I run both?
4. Should I have the ECM mapped to Stock & pull off the SERT & use the PCIII?
Pro of the SERT
1. Adjust Rev limit
2. Will have it Dynoed for max power
Pro of the PCIII
1. Self tuninug
2. Different set up tunable
I have a laptop. I have all the hadware for both tuners.
Please Help Just got done with mods now it's time to ride
Questions
3. Can I run both?
Pro of the SERT
1. Adjust Rev limit
Pro of the PCIII
1. Self tuninug
I don't have either installed on my old carbed bikes so I didn't vote. I have not used a PC so can't say which is better or worse or any difference at all. However, I have used the SERT at MMI and it is phenomenal with all the options to AFR adjustment using VE tables, timing adv & retard, displays, "Digital Tech II"-type readouts to check EFI sensor readings, can turn on or off O2 sensors, etc. too much to list all the capabilities of the SERT. Granted to each his own but if (when) I get a new bike, I will immediately install a SERT as my first upgrade before pipes or AC (we took a stock bike and downloaded for what partner was "gonna buy" for his 09 FXDWG and it ran great after dyno-tweaking: went from 66 HP to 76 with richer AFR plus shut down his O2 as "not needed")!
So, if I've got this right you're running a PCIII along WITH an SERT? If so you're making a lot of problems for yourself. If you have a good dyno tune technician all you need is the SERT. Or you could take your bike back to the dealer and have them return your ECM to stock. THEN add the PCIII and see how it runs. But running one on top of the other leads to a ton of problems. If you go to the tech section of the forum and do a search you'll find more info than you'll ever need plus some helpful hints on finding a tune tech. My personal bike has a PCIII and never ran great until I had it dyno tuned but it also has quite a bit of other mods. Good Luck.
