How to lengthen brake line?
Old 02-28-2009 | 05:40 AM
kwb's Avatar
kwb
Question How to lengthen brake line?
I have a 09 RKC w/ABS and I'm in the middle of changing out my bars to WO518's.
The front brake line is going to be short maybe 4". My dealer told me to add a braided line section underneath the tank area to get the length I need. So I have the line and the AN style fittings (which are 3" + 3" long - alone without adding any brake line).
I dont like the idea of 'adding' into the existing brake line.
Also, there isnt much room under the tank area to add all these fittings.
Stock Setup:
From the ABS unit it is hard line for about 3", then it connects to regular braided line for 4 inches, then back to a 6" section of hardline, then back to regular braided line all the way up to the brake lever.
Is there any reason why I couldnt just replace the entire line from the brake lever to the ABS unit with one piece of braided line (with a banjo fitting on each end)?
Anyone change theirs out yet?
Thanks in advance.
Ken
Old 02-28-2009 | 07:35 AM
oinker02's Avatar
oinker02
Contact Magnum Shielding to see what they have come up with for the new bikes with ABS.
Old 02-28-2009 | 08:17 AM
SG 1's Avatar
SG 1
good advise. I put the chromite II lines and cables on mine. nice stuff.
Old 02-28-2009 | 08:24 AM
zoomie67's Avatar
zoomie67
I'd buy the right size. Sounds like adding to a brake line would cause you nothing but headaches
Old 02-28-2009 | 08:45 AM
Certified Drunk's Avatar
Certified Drunk
Check out Galfer, They make some really nice stuff.
http://www.galferusa.com/html/streetlines.html
LA_Dog
03-25-2015 02:39 AM
hoethree
05-02-2013 07:59 PM
TUCCI
05-08-2012 02:10 PM
Cousy
01-14-2011 08:46 AM
Duke of HD
05-14-2008 09:04 PM
