Clutch Basket play?
I just went throught that with my 1985 flht ..
Mine was the aftermarket clutch inner bearing was bad .
Could be the case with yours or the inner primary case bearing ..
Look behind the case at the front pully to see it it moves as you
wiggle the clutch.. If it does its the inner primary case .. if it does not, then its the inner bearing of the clutch..
LenBoyLo
09-05-2020 05:41 AM
keith_lancaster
01-22-2014 08:33 AM
