"Advanced Map M15-003-016" PC V
It means there are two tables per map for each function, one for each cylinder. There are two AFR and two ignition-advance tables available and viewable. If it was a basic map you would see only one table per function and both cylinders would follow those values. Advanced is obviously better, assuming a good tune, as front and rear cylinders won't tune exactly the same.
supra0001
04-16-2013 05:39 PM
