Need Help with Garmin Nuvi 760 GPS
My Zumo 550 was stolen late last year. So I got a Garmin Nuvi 760 to get me by until the Zumo 660 comes out. If Garmin was discounting the 550, I would replace it with a 550. So far their not, so I’m going to wait and take a look at the 660.
Walmart.com (not in store) has the Nuvi 760 for $218+tax+$1.97 shipping. I also picked up a Ram Mount cradle and 1” ball for $20 so I can mount it where the Zumo 550 used to be.
My question:
How do I hardwire it to the bike?
The included car charger plugs into the suction cup base, not the 760.
The base will be replaced by the Ram Mount.
I could get a car charger off eBay that plugs into the USB port on the Nuvi 760, but I would still have to plug it in the cigarette lighter.
Can I just cut the end off the USB charger and connect it to 12V?
I thought the USB only carries about 5V.
Anybody hardwired a Nuvi?
Thanks in advance,
Rick
My question:
Thanks in advance,
Rick
The Ram Mount cradle for the Nuvi 760 is NOT powered. The power must be ran directly to the Nuvi 760 via the USB port.
If you cut the end off a USB style Nuvi car charger and wire it directly, you would sending 12V to the USB charging port.
I pretty sure that the USB port is for 5V charging.
I don't want to fry the unit.
I have a Nuvi 660 hardwired with the Ram mount. I bought it from the Mount Guys. I also bought the power adapter with cig lighter from them. I cut off the cig lighter and wired it to the headlamp harness. I then removed the radio and did the rear aux mod and plugged the Nuvi in in the back. I can listen to the MP3 player that is built into the Nuvi and get my turn by turn as well as the bluetooth from my phone all integrated into the single unit. I found tonight I can even have more music by using a SD card plugged into the Nuvi.
Life is good
Mark
Life is good
Mark
