Battery tender questions
Got up to 55 degrees today, figured I'd take the bike out. Turned on ignition, bike showed about 9V on the gauge. Hmmm...hadn't ridden it for a while, and it's been cold as heck in my garage (Indiana, it gets down to below 0 every once in a while). Fired up after a 3 second fight. Ran it for 3 minutes or so, turned it off because I had to run in the house. Came out 5 minutes later, wouldn't start. CLICK-CLICK-CLICK, just like a machine gun. Great. Borrow neighbor's quick charger, after an hour, it shows 10V, starts, and climbs to 14V. Turned off, and now it restarts easily.
So, to prevent this from happening again on my 9 MONTH OLD BATTERY, I'm going to get a tender. Was looking at the service manual, which leads to me to two questions:
1. For those of you using the quick disconnect setup, are you putting the negative connection on the chassis, or the negative post on the battery for the permanent connection? Service manual says if the battery is in the bike, to connect to the chassis when charging. Next door neighbor connects his straight to the negative battery terminal without problems for years (he says).
2. Harley has a tender for $40. Wal-Mart has one for $20. Any benefit to paying double for one marked HD?
Connect it directly to the terninals of the battery that way you dont have to worry about corrosion at the frame connection. if you connect with the aligator clips the frame connection is probably good. I have one of the Walmart and one Battery Tender (Harley). Both work but the Tender is better quality. PepBoys auto parts has them for 30.00
