Battery tender questions
Old 02-25-2009, 08:52 PM
mastery's Avatar
mastery
mastery is offline
Good feedback, I appreciate the answers. So, for the quick release pigtail, any better place to have it come out from under the seat to stay hidden? I'm thinking of tie-wrapping it to the seat frame near the front left of the seat, and sliding the AC side connector up there to do the charging.
IN Glide, it plugs right into what?
Old 02-25-2009, 08:55 PM
soos's Avatar
soos
soos is offline
Just forward of my battery is a plate on the frame with a cutout in it. I have the pigtail come out there. I just tuck it back inside when not in use and you never see it.
Old 02-25-2009, 08:57 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
You can buy the Battery Tender Plus on line for less than Harley sells the Battery Tender Jr. Check out Competition Accessories for great prices and occasional sales.
It takes 9 volts to fire an electronic ignition. You are lucky your bike started. Hook the leads up direct, plug it in every time you park your bike, and add years to your battery. You don't say what kind of bike you have, but being you are posting on the tour forum we could assume you have a bike that has stuff running all the time....clock, alarm, etc.
If so, your battery is constantly discharging when not running. That's why you were down to 9 volts.
Old 02-25-2009, 09:08 PM
captjon37's Avatar
captjon37
captjon37 is offline
Battery tender plus comes with the pigtail you put on the battery terminals and leave it. Just a simple plug with a rubber boot the gets tucked away when not used. Off topic but it is a bad idea to crank up your bike for such a short period of time.
Old 02-25-2009, 09:14 PM
Andy Engemann's Avatar
Andy Engemann
Andy Engemann is offline
I used to replace my battery every 2-3 years before using the Battery Tender. My last battery lasted 5 years. I plug it in whenever I know it will be 2-3 days between rides. Hook directly to the battery for best results!
Andy
Old 02-25-2009, 09:16 PM
RDKingRider's Avatar
RDKingRider
RDKingRider is offline
Had the tender hook up installed on my bike when I bought it, have had it on all my bikes, would not do with out one
Old 02-25-2009, 09:19 PM
IN Glide's Avatar
IN Glide
IN Glide is offline
On my 08' FLHX and on all 08's for that matter, if you look on the right side (looking forward) you will see a black cord hanging under the seat. If you pull the small cover off the end of it you will see where the tender plugs right in.
The Battery Tender is nice because it is not a constant charge. It has a computer chip inside that only charges when it needs to and monitors the battery the rest of the time. Here is the link for Battery Tender with a picture. http://batterytender.com/popup_image.php?pID=4
When you look at the picture, look at the cord that is behind the wall plug. That is what plugs directly into the cord on your bike and looks just like what is hanging on the bike. Hope that is clear as mud.
Old 02-25-2009, 09:23 PM
Jinks's Avatar
Jinks
Jinks is offline
As long as all of your connections are tight the frame IS the negative side of the battery. It makes no difference. And any battery tender will work, regardless of the price. Bottom line, your choice on both questions.
Old 02-25-2009, 09:31 PM
Razerman's Avatar
Razerman
Razerman is offline
Walmarts charger is Made by shoemaker company, they have been making chargers since the 1960s., They are quality chargers with terminal ring conections , and include a set of alligator clamp conections in the box so when your riding you can be charging the the atv or whatever with the clamp setup while your gone. 4 years no problems with both Shoemaker chargers.JMHO
Old 02-25-2009, 09:32 PM
Rollon's Avatar
Rollon
Rollon is offline
i use the battery negative ( have on 3 bikes) with no problems. Get a Battery Tender!
Quick Reply: Battery tender questions
