09 ultra two into one into two exhaust
I would like your thoughts on this. As soon as i get 1000 miles on my 09 Ultra i will install the CVO air cleaner and Rinehart exhaust slip ons but in looking over the stock head pipes i see the cross under pipe is oval and kind of flat and wonder how much loss this causes. I don't care about hp only torque. I see Vance & Hines has a new head pipe called power duals but i can't find any real info on them other than what V&H say's. Do you know if any one makes a bolt on cross under pipe.
I'm not sure this is quite correct on the 09's. With my stock system, there was slightly more flow coming from the *left* tip than the right. This was confirmed on another 09 at the same time. Keep in mind this was a hand test, holding our hand behind the mufflers at both idle and at partial throttle openings. They are now flowing pretty much equally since I installed the SE Touring mufflers.
http://www.vanceandhines.com/product...sserduals.html
+1 I had more flow out of the left side than the right.
lp
07, 09, cross, crossunder, davidson, exhaust, exhausts, flattened, harley, harleydavidson, motorcycle, tips, tw0, two, ultra
