Odometer LCD fail on 1998 RKC
![Question](https://www.hdforums.com/forum/images/icons/icon5.gif)
Took my bike to the dealer yesterday for inspection and they said they can't inspect it unless they can read the odometer, the LCD was all jarbled and unreadable. Now it was 14 degrees out yesterday when we trailered her in to the shop - I am hoping that was the issue.
My questions:
Currently awaiting a call back from the dealer with their replacement cost
My questions:
- has anyone ever experienced an issue with their LCD odometer ?
- can the odometer LCD be replaced or am I looking at the whole speedo assemply like the parts catalog illustrates ?
- any clue where to find one ? nothing comes up on CHD, Zanottis or the MOCO search engines
![EEK!](https://www.hdforums.com/forum/images/smilies/eek.gif)
i have seen several posts here and also seen several for sale on ebay that the odometer leaked. get black spots on numbers..some are lucky and it does not effect reading of miles because it is on the very edges..others black-out several numbers and make accurate reading impossible..
seen some possible solutions:
#1..go to dealer and replace with same "new" and dealer corrects mileage to speedometer.
#2..go with used same model from dealer and forget about miles.
#3..go with different new speedometer(from catalog) with different style from dealer
maybe something with rpm's or different face plate and purchase adapter for installation and dealer will update miles.
#4..purchase adapter, purchase used speedometer and forget about miles.
Because mine failed on my 99 i found a set of 07 gauges on ebay and i have adapted them over, I was not worried about the miles as my bike only had 7200 when i wrecked it 2 years ago, the speedo i got had 1500 on it....The local dealer said once i get my bike running again to bring it down and they would adjust the mileage.
Just replaced mine last weekend. I had bought one off of Ebay last spring and never gotten around to it. The only thing that I had a hard time with was spending the $195 for the crimpers for the barrell Deutsch connecters. I was able to sell them a couple of days later on Ebay for $175, but after Ebay and PayPal it ended up costing me another $25 in fees. Anyway, it was still way cheaper than what the Dealership quoted when I called them a couple of years ago.
I have found that if you use the "weatherpack" crimpers they work almost as well as the Deutsch crimpers, and are alot less cost....13 years as a heavy duty mechanic using them and never had a single issue.....
Thanks for the heads up. I thought about trying to track down some stamped Deutesch pins and sockets instead of the socket type that came with the speedometer. I found some jaws for the stamped connectors that worked with a set of crimpers I could borrow from a buddy. But by the time I paid for the stamped pins and sockets and jaws it would've probably ended up being a push money wise. I guess I would always have the jaws around incase I needed to do some more crimping.
