I can be a dunce at times too. Either everything works right for me or nothing most of the time. But this time I had no problem loading the hd dealer pois from poi factory, but I can't figure out how to load the harley shield so it shows up on the moving map where the dealers are.
Dennis
Download the HD logo image file (BMP) from the POI Factory. Then put it in the same folder on your computer as the GPX file of the same name and when the POI Loader sees it the logo will load with the POI's. When you run the POI Loader it will prompt you to specify distance (feet or meters) and speed alerts. If you want it to notify you in one mile specify 5280'. After that when you're within the specified distance and a certain altitude of an HD shop you'll see the logo. Remember that the GPX and BMP file must have the same name (except the extension) for the image file to be recognized.
