How many miles on your laced RKC wheels?
About 5000 miles on my 08 RKC and got my first flat tire. I ran over a reversible flat head/phillips head bit (the kind you would put on the end of a power drill). I don't konw if I would have been able to plug it (due to size of hole) if I had cast wheels or not but I sure would have liked the option. Had to have it towed to local dealer. Luckily for me I was just cruising around town. It sure would suck to be out on the road somewhere with no ability to fix the damn thing. Looking into some cast wheels now.
The inside of my wheel that had the spokes come loose was rusty as crap, even though the bike sits inside outta the weather. Before anybody else brings up the lube used for changing tires....I change my own and use Murphy's Oil Soap which is not corrosive.
Check out the pic. How much longer do you think it would have been till either the nipple head rusted off pulled thru or the hole in the rim rusted out enough for the nipple to pull thru?
32K on my '04 FLHRCI. Mind you, I had another bike that became my "primary" so the King sat lonely in the garage during a considerable amount of a two-year stretch while I was spanking the pavement on my Heritage Springer.
I just put a new Metzeler on the rear. It's the third tire (counting the original) so far and I put about 3,000 too many miles on the last one. I have had no problems with the wheels. Then again, I DO live in the desert. Exactly what IS rust??? LOL
I believe it.
Someone told me it was from washing the bike drying it off and putting it away. Said I should ride it to get the water out Wouldn't the centrifugal force shoot the water to the middle curve/ center of the tread of the tire, not out the nipples or edge of the rim.
Yeah, inside of my rim looked just like that.
