RK to RG parts list - please help
Marc
Here is a list i found awhile back.
Part# Qty Description List Extended Quantity Cost Ext Cost
7687 Mirror nut 2 1.1 $2.20
53600-06 1 L/S Mirror Backing Plate $1.00 $1.00 1 1.1 $1.10
53604-06 1 R/S Mirror Backing Plate $1.00 $1.00 1 1.1 $1.10
91955-98B 1 L/S Mirror $37.50 $37.50 1 29.4 $29.40
91974-98B 1 R/S Mirror $37.50 $37.50 1 29.4 $29.40
2445 3 Shield Screw $0.50 $1.50 3 0.55 $1.65
2446 2 Skirt Screw $0.50 $1.00 2 0.55 $1.10
4790 4 screw headlight bucket $0.50 $2.00 4 0.55 $2.20
58236-96 1 outer fairing primed $266.00 $266.00 1 253.11 $253.11
58208-96a 1 skirt, outer fairing $66.50 $66.50 1 43.92 $43.92
62786-96 1 trim strip, skirt $1.50 $1.50 1 1.65 $1.65
62787-96 1 seal, fairing skirt $4.00 $4.00 1 3.52 $3.52
68342-05 1 headlamp assembly $94.95 $94.95 1 64.44 $64.44
67712-83a 1 door, headlamp $40.00 $40.00 1 26.57 $26.57
67721-48 3 screw, headlamp retaining ring $1.00 $3.00 3 1.1 $3.30
67724-71 2 adjuster screw, headlamp $1.50 $3.00 2 1.65 $3.30
67726-08 1 retaining ring, headlamp $15.50 $15.50 1 12.78 $12.78
67728-02a 1 bucket assembly, headlamp $44.00 $44.00 1 29.22 $29.22
67732-08 1 mounting ring, headlamp $7.80 $7.80 1 6.55 $6.55
67778-60a 1 spring, headlamp $1.99 $1.99 1 2.19 $2.19
67782-60a 1 bracket, door $2.25 $2.25 1 2.25 $2.25
756 8 plug, deflector hole $0.10 $0.80 8 0.11 $0.88
2445 2 screw, cap assembly $0.50 $1.00 2 0.55 $1.10
2446 2 screw, trim seal inner fairing $0.50 $1.00 2 0.55 $1.10
2965 4 screw, front speaker mount $2.50 $10.00 4 2.75 $11.00
3387 2 screw, front speaker mount $0.50 $1.00 2 0.55 $1.10
3061 10 screw, fairing support bracket $0.50 $5.00 10 0.55 $5.50
3612 4 screw $0.50 $2.00 4 1.1 $4.40
10103 1 clip, adhesive back $1.75 $1.75 1 1.75 $1.75
11445 1 grommet, clutch cable $1.75 $1.75 1 1.75 $1.75
11488 1 grommet, handlbar right $1.75 $1.75 1 1.75 $1.75
11492 1 grommet, handlbar left $1.75 $1.75 1 1.75 $1.75
58311-96 2 trim seal $5.00 $10.00 2 4.4 $8.80
58478-96b 1 bracket, fairing support left $46.00 $46.00 1 30.45 $30.45
58479-96b 1 bracket, fairing support right $46.00 $46.00 1 30.45 $30.45
58199-08a 1 inner fairing $172.00 $172.00 1 113.45 $113.45
58510-96 1 cap assembly, inner fairing $42.30 $42.30 1 27.92 $27.92
58938-96c 1 support, inner fairing left $9.25 $9.25 1 7.77 $7.77
58939-96c 1 support, inner fairing right $9.25 $9.25 1 7.77 $7.77
70219-08 1 wire harness assembly $156.00 $156.00 1 103.63 $103.63
69278-06 1 bar, l/s blinker $24.60 $24.60 1 0 $0.00
69279-06 1 bar, r/s blinker $24.60 $24.60 1 0 $0.00
69292-06 2 blinker assembly $58.00 $116.00 2 0 $0.00
3684 4 blinker screw $0.50 $2.00 4 0 $0.00
34075-89 4 washer $1.00 $4.00 4 0 $0.00
3987 4 blinker screw $1.00 $4.00 4 0 $0.00
Cee Bailey's Screen $85.00 $0.00
TOTAL $1412.79 $883.27
