What do you use to get crap off your pipes?
I know this sounds crazy, cause it did when I first read it also, but a nickel will take the worst stuff off your pipes, melted windbreaker - stuff like that.
The nickel is softer than the metal in the chrome. If you don't believe me try in on one spot when the pipes are cold, but don't gouge too hard. I've used a nickel plenty of times in the same spot - you know, the one on the right side right behind the rear jug - and have no scratches on the pipe there from it.
When you have most of the heavy stuff off, put some chrome polish on some 00 steel wool and gently work off the remainder.
Works every time.
Works every time.
BS...I've been using steel wool on my softail for 12 years and never had a problem. It is 10x faster than a penny.
Buy a gallon of kerosene for $3 bucks and you'll have enough cleaner to last for years. Just dip ultra fine steel wool in it, and do your whole pipe and muffler. It will instantly remove road grime, tar, and those nasty heel marks. Wash with soapy water to remove the kerosene residue, and you'll have a shine like you can't believe.
Wear rubber gloves, however, as kerosene is a solvent and can be absorbed through your skin.
I use steel wool and wd-40, then follow up with some chrome polish or wax.
If that doesn't take it off, I go with some gas on a rag, or the EZ-Off as a last resort.
Most of the time, boot marks will come right off with a fingernail scraping. That's why I keep my chrome polished or waxed all the time......makes cleaning a lot easier.
Steve
Steve
A few years ago someone mentioned using a balled up piece of aluminum foil. Last season I came back from the store to find what looked like a serious sabotage job on my brand new pipes! Stuff was baked on the heat shields in places that could not have come from anything from the road. First I tried the WD-40. Nothing. Then I tried the oven cleaner by spraying it on a rag and dabbing it on. Nothing. I finally remembered the post about aluminum foil. It really works! And not a scratch was left by it. Followed it up with some micro polish for chrome and aluminum.
