Found SE 103" kit
Most on here will tell you to get cams, heads, etc...
But I can say I really like my stage 1 103 just as is. I think it has plently of pull compared to my last 96". Guess it depends on what you expect and what you want to spend. I may too end up with cams or headwork later...but I don't feel the need now. JMHO
I found you get more for less if you go with a different build than the SE kits, you should at least see 100/100 out of a decent cheap 103" build. opposed to the 80/85 of the SE kit. I have a pretty basic build and when on the dyno last july was seeing closer to 110hp in the California heat.
hey dmp, whats the difference between the 103 and the SE103? next ques, I take it you like the 560 cam. Do you have a dyno to post? I am in a major debate between many different cams and the andrews 550 (55H) is at the top of the list of suggested cams but have not seen a dyno from a high lift long duration andrews.
sorry bobberino, didn't mean to hijack.
