Who Has a TTS Tuner? Info Opinions?
Changing from my SERT to the TTS, lots of reading on a different forum and their website, but wondering why I can't even find a thread on here. Got some good info from Dawg which was helpful.
Anyone have any experience with them?
Any tech guys out there who have used them? From what I can see it really gives the tech options that the SERT does not. It seems the way to go to really get the right tune.
Opinions welcome. I'm not dissing the SERT, I've been pretty happy with it, but there are some throttle issues that it cannot address. The New SERT addresses some of the issues but not as many as the TTS.
The SERT was made by TTS up until the contract with HD wasn't renewed. Then HD designed thier own SEST, and TTS came out with the Mastertune.
The TTS Mastertune is virutally the same as the SERT, but they added a few upgrades to it that HD would never let them do.
I think in the hands of a good competent tuner, you're going to get just as good of a tune with the SERT as you will with the TTS unit.
Steve
Steve
I changed from the PCIIIB to the TTS Mastertune about two weeks ago, So far, I love it. Fuel mileage has gone up about 4 MPG and was able to calibrate the speedometer and the throttle is more responsive. Bought from Doc at hdmd88@yahoo.com He has been extremely helpful with my install and tweaking it for me.
Go to the fuel section of this forum and look up the post "5 Questions to ask your tuner" Doc1 appears to be the guru with that tuner. Normally, we're more into a fully adaptive closed loop system,with wide band O2's such as the Twin Tec or Zippers auto tune system. I want something that can compensate without having to remap everytime I'm on a trip. We have installed numerous Zippers system (my 07 UC is running the Zippers) and during my travels to as far south to Fla and north to South Dakota, I've had no running issues, plugs perfect, no decel popping or any other driveability issues. The bike was just pulled a part for a motor up grade after 7000 miles and piston, heads and cylinders looked great. I'm in the process of doing to 06 baggers, both running sert systems (not installed by us) and they both were running extremely lean (determined by engine inspection).
I have one, love it. If you have any EFI experience its a very simple tool. There are more adjustment than you will likely ever use without a dyno..but then again thats what is so great about it - dyno less tuning
be sure to get rid of the throttle lag by setting all the throttle blade adjustments relative to thier appropriate position
That's how I bought my SERT, it came with the guys stock ECM so I just put it in and away I went. I was able to keep my stock ECM since he didn't need one back.
Steve
