Polk Speakers
Old 02-18-2009 | 10:53 AM
52edub's Avatar
52edub
Default Polk Speakers
Can Polk Audio MOMO MMC525 speakers be used with pre-2006 touring bikes? I got these as part of a deal and can't use them with my 2009 Street Glide. The specs say 4ohm. Do they have to be used with an amp? Just want to pass them on to a friend, but not screw up his bike if they don't work.
matt
Old 02-18-2009 | 11:07 AM
aped06classic's Avatar
aped06classic
Im not sure with the momo mmc525, im in the process of putting in the new mobile monitors with the crossovers. There should be 2 wires on one side and 4 on the other. The side with two will connect with the stock speaker wire and the 4 wire side will connect to the speaker. the speaker should a co-ax speaker (tweeter sitting in side the actual driver). If you have anymore questions let me know cause my good friend is a regional manager for polk.
Old 02-18-2009 | 12:32 PM
blueflht's Avatar
blueflht
pre 06 radiosound radios are 8 ohm units so the polks will work but may overheat the unit in time
Old 02-18-2009 | 01:56 PM
molsen's Avatar
molsen
You can always use a resistor to increase the ohms. Radio Shack sells it cheap.
Old 02-18-2009 | 02:06 PM
blueflht's Avatar
blueflht
if you run an amp then as long as it is a 4 ohm amp there arent any issues. i used these speakers for about a month but they didnt last with the power i was pushing. they are marginally better than stock.
Old 02-18-2009 | 05:44 PM
Firecap501's Avatar
Firecap501
Former Sponsor
Best thing todo is run an amp, the radio will eventually give out. Pm me and I can discuss it further with you.
Danow777
Audio Systems
03-07-2014 03:41 PM
scarin
Audio Systems
02-26-2014 10:44 PM
n8dc
05-09-2009 08:25 AM
Bad Pig
08-31-2008 02:40 PM
Mongo40
01-18-2008 07:49 PM
