5th GEAR SEAL
Old 02-16-2009 | 03:44 PM
mgoblue3's Avatar
mgoblue3
Default 5th GEAR SEAL
Had the king into the stealer this weekend and long story short had to much money into the deal to even get the leak fixed that it went in for. They told me the leak was from the 5th gear seal going bad.........HOW DID THEY KNOW THIS WITHOUT HAVING THE PRIMARY APART?? How hard is it to get in an replace this seal for a novice? What other seals/gaskets should be replaced while in there?
Old 02-16-2009 | 03:55 PM
leon anthony's Avatar
leon anthony
I don't what they are calling a fifth gear seal never heard of such a thing.
ther is the inter primary seal and i supose the is a seal in the transmission between
the trans and the inter primary. but a fifth gear seal?
Old 02-16-2009 | 05:59 PM
ballpeen's Avatar
ballpeen
If your in Napoleon then your close to Napoleon Harley right there on US 24 and Industrial Drive, that is where I bought my bike. The people there are very honest, in fact I have two other Harley dealers that are very close to my house I will not deal with. What ever they are telling you, I would believe it is right. Good Luck .. Tim
Old 02-16-2009 | 06:07 PM
leon anthony
If it is the inter primary seal witch is wat it sounds to me what they are trying to say
it is not to hard to do if you have a service manual it will tell you how to take the inter-
primary off the seal is right there in the interprimary cover.
Old 02-16-2009 | 06:10 PM
twilliams's Avatar
twilliams
I have heard a dealer in my area call the shift shaft seal a "5th gear seal" not sure why they call it that,
Old 02-16-2009 | 08:54 PM
mgoblue3's Avatar
mgoblue3
So what about tearing into the primary (inner primary). How difficult is it?
Old 02-16-2009 | 09:17 PM
rbabos's Avatar
rbabos
There would have to be a seal between the pimary shaft and the fifth gear, or secondary which the sprocket bolts to. Fifth and output shaft are one and the same. If it's a 6 speed it would be 6th gear . I don't have any manuals on this trans but if you pull the primarys it should be visible . Should be able to drill a tiny hole in the seal face, put a wood screw in it and yank it out for replacement.
A manual would be a good start to get your bearings for the job as you will get into a lot of other tasks as well while doing it. Plus with the manual you will have an idea on what replacement parts or tools to pick up. Difficult no, but plan it out ahead of time and you life will be a lot easier.
Ron
Old 02-16-2009 | 09:18 PM
nocarb's Avatar
nocarb
Not difficult with a service manual and the right tools.
Old 02-16-2009 | 09:20 PM
twilliams's Avatar
twilliams
+1 on the service manual and this is not that difficult.
Old 02-16-2009 | 09:42 PM
beary's Avatar
beary
I wouldn't mind trying to fix my next one, but it only cost me $280 to fix the last one. I think $100 was in parts.
Beary
Quick Reply: 5th GEAR SEAL
