Installing SERT
Installing SERT
How many of you have installed your own SERT ? Were the instructions easy to follow ? Does it explain the differant parameters of the tuner ? I have SE Slip-ons and the SE/AC and was thinking of installing the SERT. I realize that I will need a laptop with a serial port as well.
Thanks for your input
RE: Installing SERT
Some HD techs with SERT training can't even dial bikes in properly with a dyno. Good luck doing it yourself without a dyno! Worth it to pay a pro-tuner to get your bike precise. My guy tuned the bike on the fly with his left hand on the keyboard and right on the throttle, amazing to watch. Went through every gear/rpm to match up throttle settings and AFR and tuned each cylinder individually. Could not believe the number of adjustments involved! This is something that takes time and experience.
1 Post
RE: Installing SERT
This is good advice.
ORIGINAL: bountyhunter
RE: Installing SERT
You just download a canned map to the bikes ECM. There will be a map that matches your SE slip-ons and air cleaner and you simply select it and download. It would be about as hard as posting on this forum. If you want to squeeze every last bit of torque and HP out you’ll need it tuned on a dyno. Otherwise just load a map like the dealerships have been doing for YEARS without subjecting the bike to a dyno. Some people like to over dramatize everything.
ORIGINAL: 06glide
RE: Installing SERT
Canned maps are not precise, but may be a good starting point depending on your mods and what you want to achieve. Dyno results can be DRAMATIC and may result in a bigger smile.
A canned map is fine as a baseline but the reality is the engines vary so much from one to the next that a canned map can not match your bike, even if you have the exact parts as described in the map. The combustion chamber volume and deck height vary considerable and dramatically effect the compression ratio. HD says the combustion chambers are 85cc's and most are in the 86-88cc range, but they vary from 84-90cc's. A canned map can not compensate for such differences in the engines, ONLY tuning can.
Check out this link as it will explain about the SERT .... https://www.hdforums.com/m_222256/tm.htm
RE: Installing SERT
LdyMjo
03-31-2008 03:33 PM
Duke of HD
02-05-2008 12:02 PM
