gas tank quantity
Old 04-21-2006 | 04:44 PM
06BlackFLHXI's Avatar
06BlackFLHXI
Default gas tank quantity
Has any one of you actually arn their 5.0 gal/ 18.9 L dry?
I am trying to get a sense of how accurate the light indicator is in relation to the gauge. according to my last tankful I did 300 km or 186 miles and i put in 17.1 L or 4.5 US gals. in tank that was level, so theoretically I should be able to fit another 1.8 liters or 0.5 of you crazy small US gallons
Is the stated gas tank amount accurate?
Old 04-21-2006 | 04:54 PM
2005UltraNC's Avatar
2005UltraNC
Default RE: gas tank quantity
Actually more like 5.1 Gal - all the way to the top.
Old 04-21-2006 | 04:57 PM
skos's Avatar
skos
When light goes on, your in trouble. I ran 5 miles on light before pulling into gas station
Old 04-21-2006 | 05:45 PM
fatguyona1000's Avatar
fatguyona1000
Don't trust the gas gauge at all really.
You'll notice that once it gets past 3/4 of a tank you can damn near watch the needle go down. Check it at 3/4, 1/2 and 1/4 tank readings and look at your tripometer and do the math.
I believe the light is supposed to come on when there is 1 gallon left in the tank, giving you a theoretical 35-40 to find a station.
The best way to find out what your bike has and how accurate or far it will go is to carry an extra gallon of gas with you and let it run out. Then you'll know for sure.
Fatguy
Old 04-21-2006 | 06:45 PM
Rhubarb's Avatar
Rhubarb
My light comes on at 100-110 miles.
I can usually go 180 and put 4.5 in to the fill plate.
Yesterday I was low enough at 150 on a hill that the bike sputtered and stalled (yikes).
I think I'll fill it at 150 from now on.
Don't trust the light, dont trust the gauge, just pick a mileage that works for you and use that.
Oh, and as I learned, don't push that mileage to the limits. You never know when bad gas or headwinds will lower your mileage significantly.
Old 04-21-2006 | 06:51 PM
bountyhunter's Avatar
bountyhunter
Usually do between 17-18 litres for 300-320 kms. Do not fully rely on the light or the gauge, they are just guides.
Old 04-21-2006 | 06:52 PM
lil_gmac2's Avatar
lil_gmac2
The tank is 5 gallons. Also on the new bike the light come one when you have about 1.5 gallon left in the tank.
Old 04-21-2006 | 08:35 PM
vernh59's Avatar
vernh59
My RK is 5.1 gallons. I figure my gauge is good for about 4 gallons. When the needle hits the peg I usually have about 10 miles to my reserve cough & quit. I have put 5 gallons in it before. That was a long trip. [:@]
Old 04-21-2006 | 09:50 PM
Pauljr's Avatar
Pauljr
The gauge is not that accurate. I wait until the low fuel light comes on and hit the next gas bar.
I have put in over 20 litres at a fill up.
When we ride conservative around 300 kms and when its go for broke rides maybe 220 kms out of a tank.
Old 04-21-2006 | 09:53 PM
ToadKing's Avatar
ToadKing
6th Gear
I happened to be coming to a gas station when the low fuel light came on, and it took 3 gallons to fill to the plate. I have changed the fuel filter in the tank on my 98 EFI, and noticed you could bend the arm if a person wanted to really dial in the point the light came on. The owners manual says there is .9 gal remaining when the light comes on. Play it safe,and gas up based on 36 miles per gallon and you'll never run out.
Quick Reply: gas tank quantity
