Oil Cooler: HD Premium or JAGG 10 Row?
Im running a Jagg with a manual cut off. Its mounted below the voltage regulator mainly due to running lowers, but could easily be mounted to the down tube of the frame should one choose to do so, offering more air flow through it. The manual cut off adds to the price but offers you the ability to turn off the cooler in cooler weather and should you suffer damage to the cooler where your loosing oil, it would benefit there also.
Ultra Cool makes a cooler with a fan. Pretty pricey though. I don't know if they're using a proprietary cooler or not so I can't comment on oil pressure. From the looks of their web site they will offer a fan for use with your own cooler shortly.
www.ultracoolfl.com
www.ultracoolfl.com
I live on about the same latitude in S. LA. Regardless of the air temperature the engine will take longer to attain normal operating temperature when a cooler is installed without a t'stat or bypass valve. Obviously warmer air will make this less of a problem, but it still exists. Every oil cooler that I'm aware of that's factory-installed on cars and MC's is equipped with a t'stat. I've had five turbo cars with coolers and all of them had t'stats, as does a friends BMW MC. There must be a reason if the manufacturers want to add an expensive piece of hardware like this from the factory. If not necessary the bean counters would've nixed it in the planning stage.
www.ultracoolfl.com
www.ultracoolfl.com
I'll have to keep an eye on this one, as I'd like to see their retrofit fan kit when it is ready.
With the manual valve I believe you close it before you start the motor and keep it closed while you run through the warm-up. Last thing before you get on is open it up and ride. It's located down close to the cooler so reaching it while mounted isn't an option. Unless you got creative with hose routing anyway..
www.ultracoolfl.com
www.ultracoolfl.com
i have seen it. i would us it. but getting info on it is hard.
i have asked about presure drop, got no answer that made scence.
i asked about rows, thay said 21?? that thing is small
i asked foe any real world reviews, they said they were working on that. and i never heard back.
and i asked on 2 boards if anyone has used or seen one and no one has
so i took that as a sign.
i heard from jag today , they have 2 options for my 09 ultra with the fact i will go rideing when it is 105+degs in the summer.
2 -10 row coolers, 1 low and the other hi mount.
or a 14 row that i could fab up some mounting brackets for. i will add fans to eaither one i do.
