Need wiring Help
Need wiring Help
Can somebody that has the wiring diagrams for 07 touring bike please scan the wiring diagram for the gauges in the bat fairing. I need to chase each wire for the speedo and tach. I have a older bike as in my sig but i got a set of 07 gauges for a very good price. The problem is they have the new plugs and i am having to repin the connectors. I hope this makes since. Or if somebody has the time i could just use a list by pin number and color and where it goes.
Thanks
Thanks
Hope this helps. it's out of my 09 Ultra book but should be the same as 07. With that said, I have no idea if the "where it goes" is correct for your 99 model though.....
SPEEDO
Pin 1 is Orange (ignition) goes to Pin1 on main harness (1B BK)
Pin 2 is Light Green/Violet (Serial Data) goes to Pin 13 on main harness (1B BK) and to Pin 9 on radio harness (27A BK)
Pin 3 is not used
Pin 4 is not used
Pin 5 is Brown/Grey (Battery) goes to Pin 4 on main harness (2B GY)
Pin 6 is Orange/White (Accessory) goes to Pin 5 on main harness (1B BK)
Pin 7 is Black/Green (Ground) goes to Pin 12 on main harness (2B GY) and to Pin 12 on Left Hand Controls Harness (24A GY)
Pin 8 is Black (Trip/Odometer Switch) goes to one leg of the trip switch
Pin 9 is Yellow/White (Fuel Level) goes to Pin 3 on fuel guage and to Pin 5 on main harness (2B GY)
Pin 11 is Black (Trip/Odometer Switch) goes to other leg of trip switch
Tachometer
Pin 1 is Orange (Ignition) goes to Pin 1 on main harness (1B BK)
Pin 3 is not used
Pin 4 is not used
SPEEDO
Pin 3 is not used
Pin 4 is not used
Tachometer
Pin 3 is not used
Pin 4 is not used
flynavy
12-05-2007 05:02 PM
