XM direct and Biketronics
Just curious if anyone has installed the XM direct (supposed to be underdash and controlled by the head unit) to a bike with a Biketronics kit w Sony deck. Can you control the XM with the handlebar controls? Is the relative volume of the XM to the CD/tuner adjustable?
Thanks to all for any input.
Teu
Teu
RE: XM direct and Biketronics
ORIGINAL: Teufelhunden
Teu
Teu
Yep, I have the Biketronics set up with Sony Xplod w/XM on my TC. Everything is controlled via thumb controlls, plug and play. Volume works same as other modes. You have to get creative hiding the XM componets behing the batwing to keep them secure and from exerting force on the inside of the batwing, but it definately can be done. Also I have had no luck getting a good signal with the antenna hidden inside the fairing.
The XM antenna is magnetic. I have a H-D 3-pouch windshield bag that has a metal base. I pulled the antenna up between the inner fairing and windshield and stuck it between two of the pouches on the metal base. If you dont have any metal up there you could use velcro or double sided tape.
raptorman110
2014-2023 Touring Models
26
10-19-2014 06:58 PM
