Detachable Two-Up Luggage Rack 54215-09
Because of its up curve shape (copied from the Japanese bikes), this rack only allows 8" depth for a piece of luggage. 8 inches between the passenger seat backrest and the up swing curve. So, if your luggage/tour bag is deeper than 8", and almost all are, this rack will be of no use to you. And what makes things worse, is that it's the only two up rack choice for 2009 touring model owners. So if you have an investment in luggage for your older bike and you're going to a 2009 you will have a problem. One possible solution is to buy the Tour-Pak rack 53276-09. It's actually a platform to attach the Tour-Pak. It's ugly, but while your luggage is on the bike it'll be covered up. It's a better, and cheaper, solution to replacing all of your luggage.
Not sure if you saw this too. It comes in black as well:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Rack does me wonders,
Thorey
4-Point Docking Hardware Kit - For Sissy Bar Upright, Two-Up Luggage Rack, or Two-Up Tour-PakŪ
The ideal choice for maximum versatility, this complete kit contains the docking hardware necessary to install all Detachable accessory options. Even if you only install a passenger backrest today, this kit allows you to add additional accessories as your touring demands change. Provides docking points to allow installation of Detachable Sissy Bar, Solo Luggage Rack, 2-Up Luggage Rack, Solo Tour-PakŪ Rack or 2-Up Tour-PakŪ Rack. Easy to install, these Docking Kits bolt directly to the factory drilled and threaded fender struts for perfect alignment.
54205-09
54205-09
The one you showed is below, its for an 08, down farther is the new stealth rack that will do the trick for you.
Docking Hardware Fitment Matrix
53743-97
Fits '97-'08 Road KingŪ, FLHT, FLHX and FLTR models equipped with required Docking Hardware. FLTR and FLHX models require separate purchase of Antenna Relocation for Detachabe Two-Up Accessories Kit P/N 76208-07. Does not fit with Layback License Plate Mounting Kit P/N 53385-00. Some EU registration plates may interfere with the rack.
MSRP US $209.95
Don't think it will.........But the one below might do the trick, Look it up on the HD web Site Good Luck.
Stealth Detachable Luggage Rack - Chrome
Style and practicality in one. This classic four-bar detachable luggage rack flows with the long and lean lines of today's custom rides. The rails and curving support blend together for an integrated floating look, and the "stealth" hidden hardware adds to the clean design. The detachable rack can be removed in seconds, allowing you to strip your bike for around-town riding or to simplify cleaning and polishing the rear fender.
53472-09
IN-STORE PURCHASE ONLY Contact dealer for pricing and availability.
Fits '09 FLHR, FLHT, FLHX, FLTR and FLTRSE3 models. Requires separate purchase of 4-Point Docking Hardware Kit P/N 54205-09 or 54246-09.
MSRP US $299.95
Take Care,
Bill G
