Arc Audio Install on FLTR
Old 02-11-2009 | 08:34 PM
mhud's Avatar
mhud
Default Arc Audio Install on FLTR
My HK stereo went out so I ordered a mini amp from Firecap here on the forum to have the dealer install while they were in it. (He was very helpful) They called today while I'm on a business trip in Florida to say they were concerned about it moving inside the faring when going over a bump. They used velcro to place it between the glove box and HD unit. Has anyone discovered a better way to secure this?
Old 02-12-2009 | 04:38 AM
mslater741's Avatar
mslater741
Old 02-12-2009 | 04:45 AM
mslater741's Avatar
mslater741
this is the link i was trying to find in the private message....this is how i did mine ,went to the local hardware and bought a piece of 1-1/4 flatstock put it in a vice to bend a 90 in it, laid out the mounting holes and drilled ,took like 15 minutes and $5
Old 02-12-2009 | 06:20 AM
Sincecrazy's Avatar
Sincecrazy
No more than the amp weighs, I would find it hard to beleive that it would move with velcro. Ive secured amps with velcro with no problems.
Old 02-12-2009 | 06:41 AM
UltraNutZ's Avatar
UltraNutZ
i secured both of my amps with velcro on top of the cb/xm modules. been there for about a month and have not broke loose....
that heavy duty velcro from home depot is something else.
Old 02-12-2009 | 07:21 AM
1flhtk4me's Avatar
1flhtk4me
As mslater said the amp can be bolted in.I did mine the same way.
Do a search for - "Arc 125.2/ks road glide install" and you see the pics.
Old 02-12-2009 | 07:25 AM
HDV-GLIDE's Avatar
HDV-GLIDE
I used the black industrial strength velcro to secure two HDI ballast boxes to the inner front bumper of my pick-up. Been there for over a year and have not moved.
Use some of that velcro and that amps not moving.....
Old 02-12-2009 | 07:33 AM
RODEO's Avatar
RODEO
Things sure are changin' with all you youngsters.... There was a time when good ol' "duct tape" was good enough to hold just about anything.. He He...
Old 02-12-2009 | 08:21 AM
rjmac53's Avatar
rjmac53
let us know what you decide...
Old 02-12-2009 | 09:01 AM
cfmii11's Avatar
cfmii11
Velcro will work fine.
Quick Reply: Arc Audio Install on FLTR
