Cam Swap Parts Advice
The list..
Tensioner 39954-99A
Tensioner 39964-99A
SE pushrods 17997-99A (for stock cams)
SE pushrods tapered 18404-08 (for higher lift cams)
Lifters 18538-99B (4 ea)
Cam change kit * 17045-99C (has outer bearings included)
Torrington B-148 (2 ea)
Oh yeah..don't forget a Baisley spring!
Tensioner 39954-99A
Tensioner 39964-99A
Found this listing using the Crane # Dawg posted, sets of 2...
http://www.jegs.com/i/Crane/270/10530-2/10002/-1
As Dawg stated, you can't go wrong with the H-D lifters. Would also recommend the new SE Adjustable Pushrods, #18404-08. This combo worked perfectly in my recent upgrade.
Be absolutely sure that your installer checks the pushrods for anodizing flash in the passageways. Regardless of which brand you purchase.
For the best price and service you'll find anywhere, contact HerkoBagger (John) here:
http://www.flyingwperformance.com/
Good luck!
There's a set that does, and I purchased them, but if I could do it over, I'd rather get the better SE set (look like they might be made by Andrews or Jim's?) and buy the covers. The set that comes with the covers had coarse threads as compared to the better set, and only4 wrench flats on the rod not six like the better set. It doesn't sound like a big deal, but adjusting the ones with 4 flats was a bit of a PITA as far as getting at them with an open end wrench. The coarse threads bothered me because the Hydrosolids I installed have a lot less preload on them, and it's harder to adjust the coarse threads as precisely as a fine threaded rod would have been.
Just my .02, YMMV.
Just my .02, YMMV.
17997-99A includes:
Pushrod assembly (Intake) (2) 17998-99A
Pushrod assembly (Exhaust) (2) 17906-99A
Pushrod cover, lower (4) 17938-83
Keeper, pushrod spring cover (4) 17634-99
O-ring, pushrod cover, upper (4) 11293
O-ring, pushrod cover, lower (4) 11145
O-ring, pushrod cover, middle (4) 11132
18404-08 includes:
Pushrod assembly (intake) (2) 18422-08
Pushrod assembly (exhaust) (2) 18413-08
