Detachable Saddlebag "locks"
I know i've seen it on here before, but i just can't seem to track it down. Someone had posted a thread about replacing the stock detachable pins for the hardbags, with something more secure. Anyone have a link to that so i can take a peak. I'm tired of dealing with those twist pins.
I've considered the nuts and bolts approach, i'm not really all that worried about the "quick detach" abililty of it. I dont' take them off that often, i just find that with the saddlebag wall organizer, liners etc, that i break ALOT of those pins. I'll probably just look into some bolts with a lock nut or acorn/lock nut on the inside to avoid scratching myself when digging in the bags
Just check out harbor freight and look up multi-holed clevis pins with cotter pin, you'll need four of them...Find two washers for each for a total of eight. Place a washer on and enter the backside of the mount and bag so the pin sticks inside. Now just place the washer on the inside and place cotter pin in the corresponding hole. This is a low tech lock that works great! You might need an additional washer each to make the pin meet the right hole. A lock at times is cumbersome, and really, if someone likes your bags or wants what's in them...they're gonna get it no matter what...locks or not!
Ride Safe, Mike
Ride Safe, Mike
I'm sure the clevis pins with cotters hold just fine, i'm more interested in how tight they are. I suppose you could always add an extra washer to tighten them up if they aren't fitting snugly enough as you said. Do you remove the spring portion of the existing bracket to pass the clevis pin through the bag?
For all the years I've had a bagger the only time I ever saw anybody have a problem was a goofball that took his bags off a new Road King and wasn't smart enough to put them back on correctly. One fell off while he was going down the interstate at about 70mph. He didn't know it was missing until he got home.
