**Help! - with RoadKing Shocks**
I just received my RK Shocks which came with the air tubes. I tried engaging the shradder valve to see if any air would come out. Instead, oil started to spew.
I tried removing the tube connected to the shock and the same thing happend. Is this normal? I expected air not oil.
Also, do i remove the actual brass bolt connected to the tubes? if so how? I would like to replace them with shradder valves.
thanks.
thanks.
capt_caveman
06-29-2009 08:25 PM
