radio buzz 04 ultra
radio buzz 04 ultra
What could be causing the buzzing/humming noise thru the radio.
I installed a Satellite radio - a while ago - and always had a slight 'buzz' thru the speakers while the music played - It was hardly noticeable. Just installed a set of new speakers and the buzz is much more noticeable. This is only when the satellite radio is playing. The normal FM does not have the problem.
The satellite radio power is hooked up using the cigarette lighter 12v power adapter that came with the sat radio to a new cigarette lighter accessory plug (not the one in the lower left dash) - this new one is hooked up to the extra lead coming off the headlight (power and ground) - the power wire then comes up next to the dash wires under the batwing. Also, the speakers, with the larger magnets, touch the metal brackets that hold the bottom of the speakers into the fairing. The feed from the sat radio goes to the front of my radio's aux input via a 36 inch stereo cable / jack.
I'm told its a bad ground - but all connections are tight. I did use a little bit of dialectic grease on all connections and also zip tied the power adapter to the cigarette lighter. As a side note - the buzzing level is constant - it does not change it's pitch as the throttle increases / decreases.
Any advice would be appreciated.
Thx
Thx
I'm going hazard a guess here but it sounds like what my 02 also did. I suspect it issues from the EFI, possibly the fuel pump. Since it only comes through the satellite radio, perhaps moving its antenna as far from the EFI unit as possible and using shielded cable if not so equipped, would likely solve your problem.
I didn't do anything with the 02 Ultra, just tolerated the noise. The 07 doesn't do it. Yours is a Radiosound unit, mine is Harmon Kardon. It could be the Radiosound is more sensitive in picking up noises. Hope this helps.
I had similar problems playing any accessory device that was powered by the bike's 12V power and plugged into the AUX port. Ended up being a ground loop issue, and once i installed a ground loop isolator the buzzing went away. I had the same issue both with my Zumo and the Harley MP3 player, but with the ground loop isolator, clear as a bell.
HDrider2002
thx for the response - do you recall what the name of the isolater was - where you bought it etc. Also, how did you install it, I see a few on the internet that appear to have 4 jacks on it. Is it installed on the 12V power wire - or on the wire that leads from the satellite radio to the aux input on the bike radio. ?
ex. I see this as a GLI -
http://www.radioshack.com/product/in...tId=2062214&cp
Al
Al
Update
I found this one by searching for some other criteria
perhaps this would be the right one - has the correct jacks on it...
http://www.crutchfield.com/p_127SNI1...d+loop&tp=2653
I got it from ebay, but i have seen them sold at crutchfield, etc. It goes inline with the 3.5 mm aux port wire (which in my case i just stashed in the headlight nacelle). I think it cost me $15 or so, but its well worth the price. Here is a listing for some currently on Ebay.
http://cgi.ebay.com/Ground-Loop-Isol...d=p4634.c0.m14
