SG Passing/Driving Lights Question
I have some Lazer Stars I put on in 03, 50 watts each, Kuryakyn makes the same I believe. I live in Southern California and these have come in handy when people start to cut you off or pull out in front of you. If nothing else it lights it up enough that at least they can see the shadow of you flipping them the bird!!
You should be able to see them in my signature picture.
Also about to install Kuryakyn front LED's for turn signal / running lights. Already have them on the rear and they are much better than the oem's so I am assuming the front ones will be brighter as well!
Tommorrow I am looking at ordering the Wing Tip fairing lights from eglidegoodies.
Also the factory has recently come out with some lit up fairing accents and I do not mean just the bar between the wind screen and fairing.
Not good for me as my bike is an anniversary edition and I do not want to put them on my fairing but others may HD PN #69290-09
Good Luck
Good Luck
All of the lights shown seem to work wonders compaired to the standard headlight. All in all as many have said you could have a million lights and that idiot still probably pulled out in front of you... glad you guys are ok... hope you had some kind words for that driver!!! I know I would have!!!
Here's a good view of the Harley Fog Lights turned on from the front. I had the dealer install them when I bought the bike. I can always tell when some dumba$$ starts to pull out & then sees me. Used to be that they would just pull out. BTW, trains use a "triangle of light" like this for better daytime visibility.
Start here https://www.hdforums.com/forum/touri...ng-lights.html
Let me know if I can help at all.
John
