The trim or gasket between the inner and outer fairing that goes from the edge of the windshield down towards the blinker, either because of heat or vibration, has separated in different spots. Anyone know where I can purchase a new one?
Thanks,Vaughn
Is it actually damaged or just pulled away from the outer fairing? You can remove the shield, loosen the mounting screws and put it back into place...
My 06 has done this three times.Had it fixed under warranty 2 times.
All the dealer did was re-glue the trim with some ****ty ,gooee crap that would melt when hot.They would not use new trim.
Third time I just used some super glue and no problems.
Dawg, Thanks for the part #. Boogiewithtuck, its not actually broken, but one corner is actually bent and pulled away about a quarter inch, I just got a little concerned about wear and moisture, the super glue is probably the answer too.
