Lots Of Metal In Oil HELP
I also have the ex. warranty and have done all the services except the 1K.Had to have the lifters replaced under the warranty.No questions asked.
There is a UK Harley forum where mention of the dreaded 'oil' word is almost guaranteed to get a Moderator closing the thread, with a dressing down for the guilty party.
You are running a new bike and are probably still under warranty. Use the oil your dealer recommends, nothing else, and please don't mention the 'o' word here again!
With that said, I say the oil you are using is just fine. No real reason to change. Its more of a personal choice then anything. I would stick with a good full synthetic though.
I use Amsiol as many do but there are a few other great choices as many others who are not so bothered with oil questions will tell you like Mobile 1 or Redline. Going with a full synthetic i noticed an reduction in the heat off the engine and going with a heaver gear oil i noticed a big improvement in the shifting and easier to find neutral. Worth the extra expense just for that alone.
I would say as others already have and change your oil and filter again in 500. If no major improvement is noticed then bring it in. otherwise change it again with another 1k then follow the manual. Get a sample to Blackstone labs from the 1 k change and again from the next 2 changes so they can establish a pattern for you and see whats going on. $22.50 for the sample and piece of mind.
Good luck to you and ignore the self proclaimed experts who are too busy to answer us little guys questions.
its the cheap oil that harley makes even there syn 3 is just a cheap blend made
by citgo the cheapest crap you can buy i had metal shavings until i did my homework
and found out about harleys syn3 crap and discovered amsoil a great product
engine runs cooler tranny shifts easier and guess what no more metal shavings
ride safe
ride safe
