Ultra classic heigth issue
Old 02-05-2009, 10:52 AM
don juan's Avatar
don juan
don juan is offline
My measurements no diff than yours. Ican move stock 08 around easily forward or back. 09 different story due wide frame.
don juan
Old 02-05-2009, 11:10 AM
checkers's Avatar
checkers
checkers is offline
lots of answers to this question, if you ride solo and get your feet on the ground you will be fine. riding with a passenger is a whole different matter on the e/glide with a challenged inseam. options are many, reach seat avail from HD, lowering kits for rear shocks are cheap and plentifull on e bay. steet glide may be a good choice for you. is lower out of the box and tour pack high weight not an additional concern
Old 02-05-2009, 11:40 AM
barjbar's Avatar
barjbar
barjbar is offline
I'm 5'7" and ride a RK which I think is the same height with no problems. With motorcycle boots with a nice heal, I wear Chippewa, I have no problems and my feet are flat. I also ride, short distances, with tennis shoes and have no problems. The trick is when you put your feet on the ground point your toes away from the bike instead of in the same direction. You feel your thighs grip the side of the seat and your entire leg holds the bike up not just your weak ankles. I'm on the ***** of my feet in tennis shoes without any problems. Big difference when a passenger gets on the bike also. It's so much easier to keep the bike upright when they get onboard.
Old 02-05-2009, 01:35 PM
lp johnny's Avatar
lp johnny
lp johnny is offline
5'7 w/ a 28" inseam I had SG shocks put on my '03 RK.
Now I can flatfoot w/ my HD boots..a bit higher sole and heel.
I have the HD pillow touring seat..which I believe is a bit thicker.
Old 02-05-2009, 01:39 PM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
I'm also 5'8" with a 30" inseam. When I bought my '08 egc I put the Street Glide rear shocks on it immediately and can flat foot it with any shoes including tennis shoes. Backing it up is no problem.
Old 02-05-2009, 02:39 PM
garyhendley's Avatar
garyhendley
garyhendley is offline
my mustang seat lowered it so i am flat footed also have a 30" inseam
Old 02-05-2009, 02:58 PM
Casper's Avatar
Casper
Casper is offline
I'm 5'8" with 28" inseam..I have a 07 EGC. I went with a Sun downer seat and that has help a lot, I can flatfoot the bike.
The 09 UC is a lot taller with the new tire in front, I would have to have it lowered on the 09 model...but that's doable, don't let it stop you.
Old 02-05-2009, 03:20 PM
skootchnc's Avatar
skootchnc
skootchnc is offline
don juan
Senor Juan is correct... the WIDER frame on the 09' is the problem... seat height is the same
I'm another short old fart...5ft 8 30in inseam, I was fine on my RG with the comfort stitch seat... I've played around some, and I like the REACH seat I have on it currently
I can flat foot the bike with sneakers, OR boots
Old 02-05-2009, 03:23 PM
rickoshay45's Avatar
rickoshay45
rickoshay45 is offline
I'm 5'6" with a 28" inseam and I handle my 07 fine. I did lower the rear 1" when I put the taller Mustang seat on it.
Old 02-05-2009, 04:03 PM
Snuffy1's Avatar
Snuffy1
Snuffy1 is offline
I'm 5'10" with a 30 inseam. No problems with stock 08 ultra.
PATRICKP
09-24-2018 04:24 PM
Backdraft161
The "Florida Crew" Classified Section
07-25-2017 10:05 AM
Berardi3
2014-2023 Touring Models
29
05-24-2015 09:02 PM
rcpilot_971
09-07-2008 08:15 PM
TigerladysHim
04-28-2008 12:06 PM
Quick Reply: Ultra classic heigth issue
