Need Help Engine Shacking
![Question](https://www.hdforums.com/forum/images/icons/icon5.gif)
Looking for some direction to look. Have developed a bad shake in engine not really a vibration but more of a front to rear pitch, way more than there should be. Have put new front mount in 79d, checked top mount less removing tank. Bike seems to run fine, only does this at idle, seems to get worse when Eng warms up. also have noticed increase in vibration when coming to a stop using more back brake. checked to make sure everything is tight. Can't seem to find prob any help would be greatly appreciated.
What year and model? I can assume it is a 2006 Ultra with a stage one kit, but...I don't want to make an *** out of u and me.
Also, I could not really tell you if I can't see it or touch it. My best suggestion is to bring it to a mechanic. I could be a loose motor mount, bushing or something internal. You could have a cracked frame, but doubt it. Also, note that a normal engine will vibrate more at idle and when warming up, and it does vibrate in a front to back motion, not a side to side motion, normally.
Now, you say yours does it at idle, when the engine is warmed up, and when you useing more back brake. Does it make any kind of sound? Other than the potato patato potato I mean. Does it make any knocking sound, and does any sounds, other than the pipes, change when you twist the throttle?
It all sounds like normal vibration though. How many miles do you have? Try a tune up. Check your air filter, and spark plugs. Also, have a mechanic check your programing of the PC III. You might want to check your air pressure in the tires. That can cause a wobble or vibrate sometimes.
Something else, if you have not already done it. Purchase a manual or chiltons and a good torque wrench. That way you can check the torque on your mounts. Also, check the bolts on the axles if you are notice slight wobble or vibration in the handle bars.
I don't really know what else to say without looking at it, but I do wish you the best of luck, and hope everything comes out alright.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
Almost forgot! I've seen the temp sensors go bad too. Runs fine cold, then runs too rich when it warms up as the sensor thinks the bike is still cold. Too much fuel fouls the plugs at idle. And the knee bone's connected to the thigh bone....
Kinda miss those carbs some days.
![](http://images.ibsrv.net/ibsrv/res/src:hdforums.com/get/forum/images/icons/icon5.gif)
Be very careful. If your Ultra is "shacking" up with a Softail, you may have a Dyna on the way.
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
Seriously, I dunno. How long have you owned this bike. I know HD changed the design of the front motor mount in 06 or 07 making it more rigid which drew complaints of vibration at speed. Maybe they went back to the softer mount and you just bought one?
BUT, when you find the problem, SHARE the cause with us. Too many post problems and not the solution.
Good Luck
What is the engine rpm at idle when warm??
I had the excact same problem with my 06 because the rpm was around 700.
Found PC III throttle position to be at 5% at idle. Reset throttle position to 0 and the idle increased immediately to the proper range. Shake and vibration vanished.
my2cent
my2cent
