09 FLHX PC V Questions
Greetings from SoCal,
I recently bought an 09 Streetglide and have since done the garden variety upgrades that most everyone does (A/C, Slip-ons & PC) Since the installation of the PC V I've noticed the bike running alot hotter. Most all the threads I've read from other members that have done these mods say their bikes run cooler. I had the bike parked in garage today, with a laptop computer connected to the power commander. I let the bike idle for 10 minutes or so and it had reached 311F degrees. I'm certain it would have gotten hotter. I called the company I bought the upgrades from and they said it's not unheard of at idle for these motors to reach that temp. I'm running Stage 1 air cleaner, Jackpot slipons and the map for these parts. I pulled the spark plugs tonight, there's alot of black soot around the threaded part of the plug, but the electrode and insulator are clean. The exhaust rumbles on decel, but I'm not certain that I'd call it popping. The bike runs great as far as I can tell, but I'm concerned about potential damage if the heat continues.
What I'd really like to know is what kind of temperatures other members are seeing on their bikes with similar/same upgrades. Thanks.
Matt
Matt
I'm interested as well. Just installed the same package as you tonight. Except I have stage 1 103" and the autotune modules. Did you use Jamie's basemap? Or did you have a tuner do it for you...or youself?
As far as temps, mine never went over 225 as far as I can tell BUT it was 30 degrees or so out there when I rode it. I didn't let it idle for that long. I never would suggest letting it idle for that long in warm air and without air moving over it though. Does it ride hot too, or just at idle?
Oldman, I understand what you're saying. Will have to get more feedback from the bike as I just added the new slipons last night.
Streetglider, I had noticed the bike felt like it was running warm after a 30 mile or so leg of a trip that I took. But at that point I had only done the A/C and the PC V. I used the map that Jamie sent me, and loaded the new map once I got the jackpots on. I can't complain about the bikes performance, just raised an eyebrow with the heat at idle.
Set the laptop up in the garage...then go ride for an hour or so. Come back and shut the bike off. Quickly plug in the PCV to the laptop and turn the ignition and run switch on but do not start the bike. See what the temp says. You shouldn't loose much heat in the 2 minutes it might take you to get it set up. Maybe then you'll be able to judge it better.
Mat, with todays additives in the fuel that we buy a plug read isn't as reliable as the old days. If you can call Dyno Jet and talk to them they are very helpful. I also drag race a 08 Hayabusa and use all there products. If you loaded the right map the you should be fine. I would ride it. Then check it. You can leave the usb cord in. I hope this helps because i will be doing the same as you but with Rush exhaust.
Dyno Jets tech # 1-800-992-4993
OTOH I would ride the bike for a moderate distance or more, then connect to the computer and check the temps. If you idle while connecting the computer you will see higher temps.
Jamie's maps tend to be a bit rich in the interest of cooling, but at idle he's adding only 4% more fuel on my map, and this shows up as around 14:1 or a bit higher, which is leaner than other parts of the map. Note that Jamie applies no target AFR's in the 0% column as per Dynojet's recommendation. I asked DJ about this and they held to this policy, so I have all values zeroed in the 0% column.
My temps run about the same as 09StreetGlider (225°) after a ride in air temps around 60-70°. I'm running 96ci while he's at 103ci, and that should explain the slight temperature difference. I am running 14.7:1 in the cruise range, so I'm not exactly tuning for maximum cooling at this point.
I have the mini-USB connector plugged into the PCV and a Type A male on the other end. From that point I have another longer cable with female Type A going out to the Type A male that plugs into the computer.
I had the bike parked in garage today, with a laptop computer connected to the power commander. I let the bike idle for 10 minutes or so and it had reached 311F degrees. I'm certain it would have gotten hotter. .
Matt
Matt
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
oldlefty
05-18-2015 11:17 PM
09, 2009, computer, cylinder, davidson, fins, flhx, harley, oily, operating temp, pcv, power commander, rear, soot, streetglide
